How to make a "Sharp Edge" or extrude to a Spline
Hello OnShape-Community,
the problem is a little bit difficult for me to explain so I added a picture. Basically I want the Extruded shape to extrude like a Triangle (to a single spline). I tried the Chamfer, but this messes up the Spline´s I used. Also the lenght/shape of the triangle changes on the way, so Chamfer wouldnt be correct to use, since I can only add a beginning end end distance.
1. Use the extrude feature to give the spline at the front a little bit of thickness (like 0.01mm) to create a surface
2. Select the now created surface and the surface behind it and use the Loft Button and it creates something that looks like a triangle.
Only problem this caused: one side is a bit messed up and not connecting with the other one. Here a Picture:
I guess that is an engine bug. Since when extruding an spline, the "round" spline gets reduced to something more edgy, less high polygon. I guess to increase performance. This doesnt seem to be done the same way for both sides by the engine, causing it to be unaligned.
View in high quality seems to have fixed the issue. Thank you!
