Using Variables in text
mark_morgen
Member Posts: 12 ✭
I could not get text to work at all with a #variable. I tried for over an hour, but nothing worked. My goal is to emboss a text string that includes a single dimension of the part onto a face, such as "Cube Height is #Height inches". It only works as a simple text string, but I want to update the text automatically when the dimension is changed in the drawing.
I used Onshape instructions, but they failed me...
Thank you!
1
Don't convert it back to text. Leave it as an expression. And, since your variable is just a number,
is sufficient.
I don't know if all of the FeatureScript math functions will work in a text box, but here is a good list of math functions:
https://cad.onshape.com/FsDoc/library.html#module-math.fs
Had this same issue but it wasn't working for me until I concatenated with an empty text string. Then it started working as intended, even after I deleted the empty text string. ¯\_(ツ)_/¯
