Please help with the script to Remove Extrude: NewBodyOperationType.REMOVE,
mario_acosta380
Member Posts: 6 ✭
Hello. Thank you for the help.
I am trying to do a custom script that removes material by extruding it.
I have tried multiple ways, though the material is not being removed, it is just being added:
FeatureScript 2411;
// Import the FeatureScript standard library
import(path : "onshape/std/common.fs", version : "2411.0");
// Define a custom feature
annotation { "Feature Type Name" : "Custom Remove Extrude", "Editing Logic" : "FeatureScript" }
export const customRemoveExtrude = defineFeature(function(context is Context, id is Id, definition is map)
precondition
// Input for selecting a sketch
annotation { "Name" : "Sketch", "Filter" : EntityType.FACE }
definition.sketch is Query;
// Define the constant extrusion depth
// const extrusionDepth = 7 * millimeter;
// Logic for removing the extruded material
var extrudeDefinition = {
"entities" : definition.sketch,
"direction" : evOwnerSketchPlane(context, { "entity" : definition.sketch }).normal,
"endBound" : BoundingType.THROUGH_ALL,
"operationType" : NewBodyOperationType.REMOVE,
// "endDepth" : extrusionDepth,
// Perform the remove extrusion operation
opExtrude(context, id + "removeExtrude", extrudeDefinition);
You need to do an extrude and then do a boolean to remove.
