how to create a gear that drives a ring
no_name433no_name433 Member Posts: 3 EDU
Hi,
Trying to create a gear that is driving an outer ring.
In the picture you can see the gear I created in blue near the "22" and "23" numbers.
That gear should rotate that numbered ring.
I cearted the small gear using the "spur gear" script but I am strugeling with the gear on the inner side of the numbered ring.
I'll aprisiate any help, direction, method you can offer that will enable me to do that.
Thanks
