is it possible to split this part in two?
Hey,
I would like to 3d print it in two colors. Problem is that the inner part should be black and the outer part white. My 3D printer can only print one color at time.
I mean that area inside the hole.
Thanks for your help ^^
You can definitely split an imported mesh with the split tool - at least with simple meshes. You'll need to construct an approximation of the bottom surface or the outline of the bottom of that hole, depending on which way you want to split it. Do you want the round island to be part the second color or the first?
Need some tutorials for that kind of mesh, to select the parts.
The round part should be part of the first one, the outer stuff ^^
https://cad.onshape.com/documents/6fa99ff90f5313110c19bed1/w/3c047b3267048ff08d4fb63e/e/35e90ad1cf8ca3b42074452f
The round part should be part of the outer part and would be white ^^
Here is the link for the model. Its part of are model from thingiverse - a Blastoise (Pokemon)
Thanks for your time and help Simon ^^
