How to create a counter sink hole for a wood plug
PAHPAH Member Posts: 18 EDU
I cannot figure out how to set the depth of the 3/8" hole
Here is the end goal at the assembly level
Here is what I can find online to create with Onshape
Thanks in advance,
Paul
    Hi Paul,
    I think the best way for now is with 2 hole features. The first one a a flat blind hole (the Cbore) and the second the counter sunk hole. This will let you (mostly) use the hole callout in drawings. Just make sure you match the size of the first hole to the diameter of the CSK. I'm pretty sure there's already improvement an request(s) to add this functionality as it's pretty standard.
