Having issues with FeatureScrip Extrude Remove
I don't know if my previous question went by. I will ask it again.
So, I am trying to do a custom-made feature script. The code has no errors, though instead of removing it, it is adding material. Please see my code:
FeatureScript 2411;
// Import the FeatureScript standard library
import(path : "onshape/std/common.fs", version : "2411.0");
// Define a custom feature
annotation { "Feature Type Name" : "Custom Remove Extrude", "Editing Logic" : "FeatureScript" }
export const customRemoveExtrude = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        // Input for selecting a sketch
        annotation { "Name" : "Sketch", "Filter" : EntityType.FACE }
        definition.sketch is Query;
        // Define the constant extrusion depth
        // const extrusionDepth = 7 * millimeter;
        // Logic for removing the extruded material
        var extrudeDefinition = {
            "entities" : definition.sketch,
            "direction" : evOwnerSketchPlane(context, { "entity" : definition.sketch }).normal,
            "endBound" : BoundingType.THROUGH_ALL,
            "operationType" : NewBodyOperationType.REMOVE,
            // "endDepth" : extrusionDepth,
        // Perform the remove extrusion operation
        opExtrude(context, id + "removeExtrude", extrudeDefinition);
  • MichaelPascoeMichaelPascoe Member Posts: 2,814 PRO
    edited July 2024
    There are a few different ways to do an extrude. The extrude definition you are trying to use belongs to the extrude feature not the opExtrude operation.The standard extrude feature does a lot of extra work behind the scenes that the opExtrude does not.
    If you want to call the extrude feature and use it's functionality you can do it like this:
    Note: with the latest version of onshape/std/common.fs, you have to import the extrude feature separately.
    FeatureScript 2411;
    import(path : "12312312345abcabcabcdeff/51e8dda12148fa9d3b3888d9/aff9bec3150a48098a8184ac", version : "d95598a5a22b672285115346");
    annotation { "Feature Type Name" : "My Feature", "Feature Type Description" : "" }
    export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            extrude(context, id + "removeExtrude", extrudeDefinition);
    Usually, when making a custom feature, you don't want all of the original features functionality. So opExtrude is recommended. Here is how you could do it with opExtrude:
    FeatureScript 2411;
        precondition
            opExtrude(context, id + "extrude1", {
                        "endDepth" : 1 * inch
            const extrudedPart = qCreatedBy(id + "extrude1", EntityType.BODY);
            var targets = qAllSolidBodies();
            targets = qSubtraction(targets, extrudedPart);
            opBoolean(context, id + "boolean1", {
                        "tools" : extrudedPart,
                        "targets" : targets,
                        "operationType" : BooleanOperationType.SUBTRACTION
    RENDERCAD
  • mario_acosta380mario_acosta380 Member Posts: 6
    Michael, thank you a lot. The OnShape support is amazing. Every time I ask a question it gets immediately solved. Thank you!
    Onshape has a great community. Pretty rare to find if you look at other software.
    I'm not sure how they do it. I think it's the combination of updates showing that they care, a legit forum platform, and the kind of people in general who use cad software are nice people. All these together make it a thriving forum.
    RENDERCAD
