Filter assemblies for parts without materials assigned
rick_randallrick_randall Member Posts: 412 ✭✭✭
edited July 2024 in General
Can this be done? I have several large assemblies that have incomplete mass properties because I can't find the one out of a hundred(s) parts, that don't yet have materials assigned. Looking for an easier way to find them. Any ideas?
  • Caden_ArmstrongCaden_Armstrong Member Posts: 373 PRO
    What about adding "Material" as a column in the BOM?
  • rick_randallrick_randall Member Posts: 412 ✭✭✭
    edited July 2024
    @Caden_Armstrong - That just might work. Thanks, still wish it were a filter option though.
    Edit - Does work, only took 45 secs. to find 2 parts out of 489 parts. Nice work around, I will remember, and recommend this.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 894 PRO
    You could export the BOM as CSV and then filter?
    Matt, your suggestion may be valid, but Caden's idea was so simple and easy, I think that's the way I'll handle this type of situation. Thanks for the response.
