FS get and set properties
graham_lock
Member Posts: 265 PRO
Hi all,
I'm simply trying to get / set the name property on parts.
If I try reading the name property I get the following error:
@getProperty: Cannot get properties during feature regeneration
If I try to set the name property I get the following error:
Precondition of setProperty failed (definition.entities is Query)
I would have expected this to be simple so I'm probably missing something.
Test document at:
Any help appreciated.
Thank you.
Matt_Shields
Member, Onshape Employees Posts: 846 PRO
If you haven't done so, I'd take the FeatureSciript course in the Learning Center.
https://learn.onshape.com/learn/course/featurescript-fundamentals/introduction-to-featurescript/featurescript-introduction
Also, here's a simple custom feature that renames parts. Take a look at its code.
https://cad.onshape.com/documents/64b50e5bc8361661aeb6c1f6/w/919a68c15737d7e96bf07b66/e/4d32423cb852bf388b384783
_anton
Member, Onshape Employees Posts: 505
BTW, what may not be obvious is that you can't get properties in a feature, only set them. Properties are often set after feature regeneration, so, while the feature is being executed, you wouldn't be guaranteed to get the right value. getProperty will only work in custom part property code and custom table code.
If you just want to store metadata on parts, use attributes.0
