dimension text not showing
ken_nicholsken_nichols Member Posts: 2 ✭✭
Why  doesn't the dimension text show when I add a dimension to my drawing?
  • S1monS1mon Member Posts: 4,077 PRO
    Can you be more specific? What text are you talking about? Unlike Solidworks, there's no text notes in a dimension in Sketcher.
    In drawings, you can add text to a dimension before or after the dimension, like so:
  • ken_nicholsken_nichols Member Posts: 2 ✭✭
    When I insert a dimension in a drawing, the actual dimension is blank, and when I try to edit it, it looks exactly like the example above.  Dimensions are even blank on drawings that I have done previously.
    @ken_nichols
    That sounds like a bug, or perhaps something weird with your browser set up. I would report it to support.
