Offset failed with spline ?
Hello, I was wondering, is it possible that the Offset tool does not work combined with the Spline tool. No matter what I do, I always get the same error message: "Offset failed. One spline generated multiple offset curves." However, with the other tools (Line, Rectangle, Circle...), Offset works perfectly...
Here is a link to my sketch Thank you
https://cad.onshape.com/documents/08f5a4f57eaa7f2780921802/w/79fbe2859137679a4481706f/e/212af11deaf965272a6ae453
  • S1monS1mon Member Posts: 4,040 PRO
    You have some areas of very tight curvature. You can't offset a curve more than the minimum radius. In this case that's 0.031. Also offsetting surfaces can be more robust in extreme situations. Using surface offsets, I can offset to the inside by about 5mm and to the outside by 0.03mm before things fail.
    If you broke your sketch into one spline per petal, you'd have a lot more ability to offset to the outside.
    The offsets I did here are surface offsets. I couldn't get 5mm using a sketch offset. This is a trick I learned with Solidworks which also applies in Onshape. Whatever the algorithms are for offsetting curves in a sketch are different than what's used to offset surfaces. Sometimes surface offsets are more robust or at least allow more of an offset than sketches.
  • andré_lemelinandré_lemelin Member Posts: 4
    For my part, if I try to indicate -1 mm as a value (to place the Offset inside), the tool gives me the same error message "Offset failed. One spline generated multiple offset curves".
    On the other hand, now, following your answer, I tried -.031 mm (for the interior), and the tool accepts my choice. Then I can change the -.031 mm Offset to -1mm.
    There, it works.
    I find it a bit strange that I have to do 2 maneuvers for an action..
    In any case, thank you very much for your response!!!
  • david_velozdavid_veloz Member Posts: 4 ✭✭
    I had the same issue and couldn't change the offset distance in the iOS app. The web-based app had the same error, but worked when I clicked into the offset measurement to adjust.
