How to set dependencies in configuration tables?
Is there a way to drive available parameters based on another parameter in configuration tables?
Example 1:
Filter "Face" list depending on the "Size" selection (i.g. if I had selected a size of 1/2", "Face" would show only available options for that size.
Example 2:
Suppress a field to select if it is not available for a specific configuration (i.g. hide or grey-out "Face" field if there weren't any options for 1/2”.
Example 1:
Example 2:
eric_pesty Member Posts: 2,251 PRO
Short answer: no...
But there are a couple improvement requests for this.
You may be able to work around it by creating a new part studio and deriving your part in and configure it to create "subsets" of all the possible combinations (depending on the dependencies and number of possible permutations...).
Here are a couple of examples of this: https://cad.onshape.com/documents/d2d3382aa18189471db96624/w/bfdb4819bc7e743e462a92ad/e/671f31135deee56ac9da53da0
