How to extrude with curved direction please?
fire_wheelsfire_wheels Member Posts: 2
Good day guys!
I'm completely stuck with my drawing trying to keep a geometrical holes curved to preferred line at the right plane, please help :)
Yellow surface is what I'm trying to extrude, kind of sample:
https://cad.onshape.com/documents/0666be73a577f13e1b75bc68/w/8f98bc3eacf676f536595a2a/e/76f73d9b0244879fc67c6695?renderMode=0&uiState=66a8cbea841560686c5665d5
Thank you!
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,557 PRO
    Not quite sure what you are trying to do...
    "Extrude along curve" sounds like a "sweep" feature to me. But if you want to extrude straight to the right but have the face match the curve you would do it in two steps (extrude larger and cut using the second sketch shape, or extrude the second face as surface and use "up" to in the extrude)
