Won't allow an extrude
https://cad.onshape.com/documents/1b6baae2514cfbec70810e3a/w/26dda2dd32cc651e17edd33f/e/b710cae0f1a4b7201214529c?renderMode=0&uiState=66b24b63e3c77e6059dbf8bc
I am attempting to extrude 'Sketch 16', inward .300", but the drawing simply will not take - no errors given, it just refuses to display the extrude. I've reduced the depth, moved Sketch 16 side to side, but it just won't accept it. What am I missing?
Make sure you're extrude-removing, and in the right direction.
The part you're trying to model can be done with just 6 Feature items...your feature tree has 30!
