Google Sheets Cell values for Variable
Hi Team,
I am brand new to onshape and testing out the functionality.
Can I get variables from a google sheet?
A simple example would be cells with the values 200 and 400
These cells are some how referenced in onshape to create a rectangular sketch that is 400x200.
I have searched the forum and there are a few mentions of this feature in demand from many years ago.
I have the variables set in my model and I have linked the google sheet into my model via the Link Tab
I just can't get onshape to suck the values out of the sheet and apply them to the model.
Thanks in advance
Thanks in advance
Matt_Shields Member, Onshape Employees Posts: 656 EDU
Not natively. You could paste in values from a Google Sheet. Or write a python script to read the sheet and update your document via the API.0 -
I'm by no means an expert, but I got a little test working. I started here:
https://developers.google.com/sheets/api/quickstart/python
I followed that exactly. Once I had my Python code reading my Google Sheet, then I just updated a Variable Studio using Python requests to the Onshape API.
By the way, after I was done, I also found this:
https://github.com/PTC-Education/PTC-API-Playground/blob/main/Configuration_Variables_and_Google_Sheets.ipynb
2
Does the python sheet get written in Onshape or google, Is there any great help resources for this or potentially someone that may be able to help in this regard.
