Change language for drawing only
daniel_crookstondaniel_crookston Member Posts: 18
I'm working in a foreign country right now and would like to print drawings in a foreign language without editing all the fields manually.  Is there a way to do this without changing my entire account to the different language?
Thanks!
    Do you mean change the language of your drawing files, or change the language of the UI?
    There's no existing way to automate translation of files. But you can select an alternate language for the UI.
  • fabian_mühlberger066fabian_mühlberger066 Member Posts: 16 PRO
    I am having the same issues with my Austrian sheet metal fabricator. The guys on the shop floor misread "up" for "ab" which means down.
    Even thought I set the language to German, and in the drawing settings do German, it seems some translations are missing and always show up in English…
    I would appreciate it if you could look into that.
    Best
    Fabian
  • daniel_crookstondaniel_crookston Member Posts: 18
    Yes, this is exactly the situation! I am working in English but my clients speak a different language. I guess I need to post a feature request.
