How to fillet this hole?
tuure_ahonentuure_ahonen Member Posts: 6
How can i fillet this hole? I'd like to create an countersink hole here. Filleting tool is saying "unfilleted edge overlapped by fillet". the fillet also tries to generate in very strange way
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 840 PRO
    You could use an implicit mate connector at the end of a sketched line.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 367 image
    Can you try a smaller fillet radius?
  • tuure_ahonentuure_ahonen Member Posts: 6
    This helped! I just got started on learning onshape and it did the trick! Thanks for the help!
    I will definetly give this method a try aswell! thank you for the replies!
