FS cPlane angled plane
graham_lock
Member Posts: 265 PRO
Hi,
I'm trying to create an angled plane using the code below:
I'm not sure if this is the way to go about it?
If it is the correct way how do I pass the sketch line to cPlane? qCreatedBy currently fails.
Thank you.
var sketch = newSketchOnPlane(context, id + "angledPlaneSketch", {
"sketchPlane" : refPlane
// draw line for angled plane
var lineMap = skLineSegment(sketch, "angledPlaneLine", {
"start" : vector(0, 0) * millimeter,
"end" : vector(50, 0) * millimeter
skSolve(sketch);
// now create angled plane
cPlane(context, id, {
"entities" : qCreatedBy("angledPlaneLine"),
"cplaneType": CPlaneType.LINE_ANGLE,
"angle": definition.angle,
"oppositeDirection" : definition.angleDirection
Thank you.
Caden_Armstrong
Member Posts: 412 PRO
You are probably better off using opPlane. Ultimately, cPlane is calling opPlane, it just has some extras for the user.
All you would need to do is calculate the normal direction of your plane (and the origin), which will be a lot less work.
qCreatedBy is failing because the Id is that of a sketch entity, but that query type takes in the feature id ("angledPlaneSketch"). To use that sketch line, you need to do something like qCreatedBy(id + "angledPlaneSketch", EntityType.EDGE); As its the only line in the sketch, quering for all edges made by the sketch should produce only that edge.
Or you can do sketchEntityQuery(id + "angledPlaneSketch", EntityType.EDGE, "angledPlaneLine"); if you were to have multiple sketch lines.
www.smartbenchsoftware.com --- Renaissance --- fs.place
Experts in Onshape Automation - Custom Features and Integrated Applications2
