how do i create a solid from these two sketches
martin_kopplow Member Posts: 996 PRO
Close the sketch on Plane 2 horizontally at the bottom, forget about wall thickness for now, extrude the single resulting sketch surface, then use the sketch on the Top plane zu cut it to shape or rather just remove the corner, add the fillet to the cutout, then use the shell tool to hollow everything out.
1
what kind of object do you want to obtain? Those two sketches are not enough
https://cad.onshape.com/documents/f821c0996e88febf3789b97c/w/64c4a339bf1e61f2c3246290/e/30c6dd59835b6915b8c9f024?renderMode=0&uiState=66c471808a68780a337dd035
i want to make a enter key cap. so de top sketch needs to match the bottom sketch outlines. I hope i can make myself clear.
thank you very much
If I well understood you can try this:
