how do i create a solid from these two sketches
wouter_brilwouter_bril Member Posts: 6
  • martin_kopplowmartin_kopplow Member Posts: 872 PRO
    edited August 2024 Answer ✓
    Close the sketch on Plane 2 horizontally at the bottom, forget about wall thickness for now, extrude the single resulting sketch surface, then use the sketch on the Top plane zu cut it to shape or rather just remove the corner, add the fillet to the cutout, then use the shell tool to hollow everything out.
    https://cad.onshape.com/documents/f821c0996e88febf3789b97c/w/64c4a339bf1e61f2c3246290/e/30c6dd59835b6915b8c9f024?renderMode=0&uiState=66c471808a68780a337dd035
  • Roberto_VerduciRoberto_Verduci Member Posts: 29 ✭✭
    what kind of object do you want to obtain? Those two sketches are not enough
  • wouter_brilwouter_bril Member Posts: 6
    i want to make a enter key cap. so de top sketch needs to match the bottom sketch outlines. I hope i can make myself clear.
    thank you very much
    edited August 2024
    If I well understood you can try this:
    1. create top sketch (like the one you've drawn but just the external profile) image.png
    2. create a front sketch (like the one you drawn but just the external profile using the vertex of the top sketch to define the width) image.png
    3. Extrude the first sketch up to the upper vertex of the second sketch image.png
    4. Extrude the second sketch in 2 directions up to the external vertex of the first sketch image.png
