How to combine two faces?
willmac829
Member Posts: 3 ✭
Hello all,
I am using a CAM software, and essentially I need a way to "combine faces", e.g. take out the circled line in this picture:
Is there a simple command I am missing to combine them, or a technique? Thank you for any help!
You could use the Delete face heal feature. Another way would be to use Replace face and select one face and replace it with the other.
