Default parameter syntax?
Emily_Qi_Wang
Member Posts: 13 EDU
What is the syntax for setting default parameter values when defining a new feature?
I checked the doc files and SCOPE Weds slides that Kevin sent recently and didn't see this mentioned; apologies in advance if it's obvious and I missed it.
Code excerpt example (Also, are there code blocks in the Onshape forum discussion editor?)...
precondition
annotation { "Name" : "Radius" }
isLength(definition.radius, LENGTH_BOUNDS);
annotation { "Name" : "Teeth" }
isInteger(definition.teeth, POSITIVE_COUNT_BOUNDS);
// function action stuff here //
{ /* default parameters can go here?? */ });
For the default parameters block, I tried a few things:
* "definition.teeth" : 10
* definition.teeth = 10
* "Teeth" : 10
* and so on...
Thanks in advance!
* "Teeth" : 10
* and so on...
Thanks in advance!
{ teeth : 10 }should do it. Also{ 'teeth' : 10 }. We have code blocks. Switch to HTML mode with the slash-in-angle-brackets icon and use code.../code around your code block.annotation { "Name" : "Merge with all", "Default" : false } booleanDefinition.defaultScope is boolean;Default works for string, boolean, and enum. It doesn't work for number. I doubt there is a strong reason for it not working for number. Somebody needs to write the code. Maybe we'll get a feature request...In this case, the thing to do is to make a local copy of POSITIVE_COUNT_BOUNDS from valueBounds.fs and adjust the middle number (the default).
