Help! Why can't I wrap this object around the cylinder
Hello,
I'm newish to onshape, done the some of the basic tutorials, and made some semi complex items, but I am running into a problem with this project why can't I wrap part 3 around part 4. Apologies if this is a super dump question, and thanks in advance!
Here's the link to my project https://cad.onshape.com/documents/9ffe9f9d9ff881e9928dd02e/w/9b3c0e4b2ec03d834d635a7a/e/6c5f9d607641482eb28a665a?renderMode=0&uiState=66d0dd469440783230c95585
  • S1monS1mon Member Posts: 4,036 PRO
    With the built-in tools there is no way to wrap a solid around another shape. You can wrap 2D curves around a cylinder or cone - that's it.
    There are some custom features like Texture and Attractor Pattern which can do some interesting things, but not exactly what you want.
  • james_blackwood029james_blackwood029 Member Posts: 4 EDU
    Simon, does this mean if I were to leave my object as a plan sketch I would be able to wrap it?
    Yes. You can wrap a 2D sketch.
    See the help.
