stress raisers at intersections in assembly
rod_puckeyrod_puckey Member Posts: 10
I can create an assembly from individual parts.
This leaves sharp corners where the parts are joined to form an assembly. This forma a stress raiser that will lead to failure.
How do I insert a radius between parts in an assembly
I've tried Boolean command but it doesn't work on an assembly.
There must be a way, but I cannot find it. Please help.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 930 PRO
    You are correct that sharp corners create stress risers in parts. But, joints between parts are by definition discontinuous. Adding a radius between discrete parts won't create smooth stress distributions. You will want to create the parts in a part studio and use boolean to join them together and then add fillets.
  • rod_puckeyrod_puckey Member Posts: 10
    My mistake, the sub drawings are parts of a whole finished item machined from a single billet.
    5 variants, 3 sub drawings are common to each variant.
    From your reply, am I correct in thinking that I must create ach variant from scratch as a single part, not using sub drawings?
    The assembly is made of a number of sub assemblies of a whole finished item. Creating them as discrete parts allows me to use individual sub assemblies in a range of whole finished items.
    From your reply I believe that you are saying that as soon as I take discrete parts and make them up into an assembly I cannot then modify the assembly. That will fail in this case.
    Does this mean that if I have 5 finished parts, Machined from single billets, that are made up of 5 sub drawings, 3 of which ae used on all finished parts, I must make the 5 finished parts as complete parts not using sub drawings?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,583 PRO
    edited September 2024
    Assemblies in parametric CAD implies separate parts that are fastened together (often with some degrees of freedom) but do not create a single solid.
    I think what you are looking for are "derived" parts and/or configurations.
    Something like this:
    https://cad.onshape.com/documents/d51e39f89aa3fa951f302d1d/w/eabcf7323125f9cbe024c874/e/28817e34ff91083ef01042d7
