I cannot see what i'm doing wrong
michael_fitzpatrick053
Member Posts: 44 ✭
I'm trying to complete the attached piece but for the life of me I can't see what i'm doing wrong.
It's a simple shape but for whatever reason…….
The top line is 40mm from left to right. it then turns downward 90 degrees for 50mm. At the end of that line it comes upward at a 55degree angle then an arc between that point and the starting point.
The arc represents the shape that is against a wheel with a 150mm diameter.
Any help please?
https://cad.onshape.com/documents/ee2d67aa4c0dc0928de1e727/w/edf938a043dd7cec90776074/e/89678b0046afd03cafd5b173
Matt_Shields
Member, Onshape Employees Posts: 930 PRO
What is the problem? It looks like you basically have it.
@Matt_Shields
Thanks for the response, I cleared the job and re-did it and it worked as I wanted.
It wouldn't work for me prior to my posting…..honestly😀
All good now.
