Loft generates surface but not solid
mubin_icyermubin_icyer Member Posts: 13
edited September 2024 in General
Hi,
I want to generate a loft between two profiles generated by Profile Generator script (airfoil) but I cannot generate a solid loft between two profiles. Only surface loft can be generated.
Another interesting thing: There is no Sketch 1 in my document. Why does Loft show still "Face of Sketch1"? I deleted lofts, profiles completely and draw again, but it still shows Sketch 1.
Thanks.
https://cad.onshape.com/documents/8b24f97526fb35d8816153f3/w/e9da5f0e65563117e29483eb/e/53c53f9e77de2e1a8b5a0dc0?renderMode=0&uiState=66d8379a87ee83404c1e2a96
  • mahirmahir Member, Developers Posts: 1,315 ✭✭✭✭✭
    Generally, more segments/points in a profile will make for a more problematic loft. Ideally, your loft profiles have the same number of points. You can also adjust where points are mapped profile to profile.
    I'd like to take a look, but you need to change the permissions on your document to allow copying.
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 151
    Surface loft + 2 Fills can create a Solid. Not sure why I cannot be done otherwise.
    https://cad.onshape.com/documents/a729bfc94eb46144ff56c731/w/ce634d10c468b306c6e06ea6/e/8d799697f0ff53a446214065
  • mubin_icyermubin_icyer Member Posts: 13
    How can I change permissions? I have only this:
    Thanks but now I have problem combining two parts with boolean. I want to add newly generated part (surface then fill) to another part but I can generate only new surface not "add surface".
  • robert_scott_jr_robert_scott_jr_ Member Posts: 578 ✭✭✭
    This worked on the loft. - Scotty
    ucak - Copy | Tail main (onshape.com)
    Ok , I think I found the issue. Profile generator has some settings including accuracy. When I increase the accuracy, loft worked without problem. I think feiner setting in accuracy causes airfoil profile not closing.
