How to have number of part instances driven by a variable?
david_lynch037david_lynch037 Member Posts: 4
Hi. I have this part that is a wheel with cylinders on the edge of a wheel, such that the cylinders all touch each other. The wheel is 20 inches in diameter, driven by variable #dia. I would like to be able to change the diameter to 40 inches, by changing #dia, and get more cylinders on the wheel, so that they touch. Right now, there are 18 cylinders, but when I change #dia to 40, I would want enough cylinders so that they still touch each other.
Also complicating this is that there are some values of #dia that will be impossible to fill completely with cylinders. I can't have 1/2 a cylinder or gaps between cylinders.
Is this possible? How do I model this without manually iterating over the pattern tool, trying to find the perfect combination of #dia and the number of cylinders to support scaling of the part to various diameters?
Here is the design:
https://cad.onshape.com/documents/7aef99bb7ab5475c70e92f74/w/cc4a7dc99b6308703b4d0870/e/b7d556c02a14e7bba7fa223a?renderMode=0&uiState=66db9a613ffdfa79fcd6ca40
Thanks!
