How to deal with un-fixed parts in Assembly's
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
My go to workflow for the start of an assembly is a Group Mate and Fix 1 part to lock things down but these are not always applicable when woking out the desired mechanism.
Sometimes parts that have come into the assembly in position from the part studio get moved and I don't find it easy to get them back to position. I also find myself moving parts to see what's constrained and whats not, then using undo to return parts to position, you are in trouble with this if the undo is missed.
How do others deal with unfixed parts in an assemblies when accidentally moved out of position?
3dcad
Member, OS Professional, Mentor Posts: 2,482 PRO
@brucebartlett Of course it depends on how big project you have but I have found myself simply deleting the unintensionally moved part and insert again.
//rami5 -
Narayan_K
Member Posts: 379 ✭✭✭
Hi@ brucebartlett , You can also get the original position by restoring the history.
5 -
3dcad
@Narayan_K The problem with history is that you lose work that is done after accidentally moved a piece. I remember having conversation about selectable history restoring regarding to something else with Onshape, that would serve this purpose too.
@viru When you say 'fix constrain' do you mean actually fix or group mate? If you use fix to constrain things together you will have problems if that assembly is used as subassembly since fix doesn't apply in parent assemblies.
Best way to keep stuff together is to use group mate but it tends to forgot sometimes if you begin assembly with incomplete part studio and keep adding parts one by one and check assembly in between.
+1 for 'Restore selected part(s) in Part Studio position'//rami5
And join this class: https://www.onshape.com/assemble-onshape-oct-1
1) when you can not get the part back to position, you can suppress it ,and check if some mate feature turn red,so you will know if it is constrained or not.
2) in the mate feature window ,we just can "offset" the first mate connector,but if we create a mate connector first, in the mate connector window , we can "move" the mate connector,it includes "offset "and "rotate about any Axis",so you can adjust more data
In this case I deleted the part and re inserted again as @3dcad mentioned. There were however mates connected to this part which had to be re done, that was what I was trying to avoid. I did briefly look for a reset part to origin, this may be a nice feature to have.
It would indeed be good to have a 'Restore selected part(s) to Part Studio position'
Previously similar option is available in assembly as shown in below link.
https://forum.onshape.com/discussion/306/improvements-to-onshape-january-27th-2015
(In addition to the origin in Assemblies, you can now use the manipulator to move selections to the origin, rotate 90/180 degrees about any axis or align/anti-align to Z on any manipulator direction).
@3dcad ,I am using "fix" option only at initial stage after inserting of part in assembly after-that "unfix" part one by one and giving constraint as per their functional requirement. At the end non of the parts in assembly is containing "fix" option and all the parts in assembly should contain at least one mate constrain as their functional requirement. By using this method user can know how much parts remained to give constrain in assembly which is equal to parts having "fix" symbol. It also avoid unnecessary movement for parts at the time of assembly creation .
Kindly refer below video for more clarification.
Thanks for sharing it.
