Can't loft two faces.
tristan_mcgarrytristan_mcgarry Member Posts: 3
Hi I'm having trouble to loft and can't work it out. Does any one know how to do it? Any help appreciated thanks.https://cad.onshape.com/documents/7bf015afd3b6d4ce39e2e1bf/w/6ee02b33a1cf2204fd7bd259/e/1749306a4c2a7045c2025998
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 372 image
    As the error message states, you can't use a face containing inner loops as a profile.
    You might want to try a "Thin loft" using only two circular edges as profiles?
  • _anton_anton Member, Onshape Employees Posts: 510 image
    The loft error explains the issue. You could use two lofts, one for the overall shape and another that removes the internal region.
