Introduction to Sketching will not load
I am trying to have my students access the "Introduction to Sketching" lesson but it gets stuck loading for me. It opens for me but they cannot access it. When looking into the details it says that Proficiency in parametric 3D CAD is a prerequisite but I cannot find that course. Any help is much appreciated.
Hi. I have a separate issue with this module, but I saw this and thought I'd try to help. The "Proficiency in parametric 3D CAD" module is strangely difficult to find. I don't even know how I originally found my way to it, but it was the first one I did (I think it's advertised on one of the first pages after you first log in, but I'm not sure). Anyways, I managed to find it after digging around for a while. From the "My Training Dashboard" page:
*Under "Learning Format" select "Course"
*Then select "General"
* It's the last of 6 modules, I believe.
Hope that helps.
(PS—the issue that I ran into is the quiz at the end… It has them make a simple sketch that is supposed to be "fully defined," but unless I'm missing something, it's really not which makes the final question about figure area a bit of a random guess. Let me know if you run into the same issue. Thanks.)
