Is there a Way to Manipulate Specific Parts of a Loft
cyrus_costa541cyrus_costa541 Member Posts: 54
I was lofting a surface and it went from a large line to a point. However, when I did this it bunched up in the wrong places and has created these undesired folds in the surface. I might be able to fix this by adding a bunch more guiding curves but that would be very time consuming and would take a ton of work. So I was wondering if you could just manipulate specific points on the surface. For example you have the option to "enable isocurves" but these are only for viewing, is there a way that I can set specific points at the intersections of these isocurves. This would accomplish the same as adding a bunch of guiding curves however this would decrease the workload a lot.
P.S. I saw someone using solidworks and I think they where able to do this in there but I do not really understand solidworks and so it would be much more helpful for me if I could do this onshape.
