Enclose Question
brett_pearson524
Member Posts: 4 ✭
Hello,
I'm a total Onshape novice. I am designing a boat and I am wanting to enclose the area below the waterline 60 plane to calculate volume for buoyancy. I have thickened fills for the hull, along with an extruded keel, but i imagine i must connect them all to close in the hull to use enclose?
I am attaching a link to the file for the boat(I think :)). Any help would be greatly appreciated!
https://cad.onshape.com/documents/a15d1fc54e36ccd6fd1d123f/w/272e67709bf7f55e3a1ca41e/e/531f4d7f25a99291375896a9
There are a few ways to do this. Enclose is a good way, it does require all holes to be sealed. Simplify is another one which is a custom feature.
Since this part is not very concave, an extrude and boolean approach would work well:
https://cad.onshape.com/documents/3c30fe1ad85b261e03a1c82e/w/5b8a45349f1b8c6b88cc0a7f/e/3f00525b51bb3a7f37…
RENDERCAD
Wow, thank you so much. I will get busy learning this process.
