Assembly Linear Pattern Help
I have an issue with the linear pattern feature in my assembly. If I add the small trays individually, I can pull each one out independent of the others. However, when I use the Linear pattern to add additional small trays, I lose the ability to pull them out. In the image attached Ihave one of my large trays pulled out. The small trays are using the same extension slides, but I can't slide them out when I use the linear pattern feature.
Is this normal or a bug?
This is normal…
If you use a replicate feature instead of a linear pattern then you can move them independently
Where do you find "replicate feature" please?
