Multiple derives not allowed?
S1monS1mon Member Posts: 3,985 PRO
This is a new error for me. Until I have time to create a proper custom feature, I was using a part studio with parts for injection molded boss features. That was great until I tried to derive the same bosses in two different derive features in the same part studio, and I got this error. Is there some good reason why this is not allowed?
Also, why was this scolding message about not using derive to create assemblies added? I'm using it to create the same sets of features in different parts of the same part studio.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,549 PRO
    Yeah that seems a bit drastic… My understanding is that it's for performance reasons and deriving multiple times from the same ps and config was always against recommended practice and not it's explicitly not allowed….
    I guess you could derive once and then use transforms (or transform patterns) to add other derived instances of the same. Or use the good old "super derive" FS which should still work the same way.
  • S1monS1mon Member Posts: 3,985 PRO
    The other thing that I'm reminded of is that derived parts get the same name as the originals but the appearance doesn't carry over. This is frustrating since I was trying to use color coding to make it easier to grab the right parts for further operations. I could see this being an option, but I don't know why it just throws away the info.
  • code_makercode_maker Member Posts: 2
    Funny workaround:
    1. Go to the part you want to derive twice.
    2. Go to configuration, and add a new dummy configuration variable. (I made it a text type, but I suspect anything works.)
    3. You don't have to actually use the variable anywhere :D
    4. Derive the same part and config twice, except that you give a different value to this new dummy variable.
    5. You now have two identical parts, but this weird check of disallowing the same config twice thinks the parts are different because of the dummy config variable
    I have no clue why this is a limitation. It is definitely not performance:
    • I don't see why importing the same config twice is more expensive than importing two different but similar configs
    • This can even be an optimization: they have proven to be able to detect duplicate configs, and they can just copy the previously derived part, instead of generating the same config twice
    Maybe something weird can happen sometimes if you derive the exact same shape twice. But if so, then this error check fails to prevent that, given the dummy variable trick works.
    Does anyone know why this is a limitation, or can the devs just remove this limitation maybe?
