If anyone can help with this double inverted pyramid I'm trying to sheet metal :(
elena_sknny
Member Posts: 4 ✭
hii, I'm very new obv:
If anyone can help with this double inverted pyramid I'm trying to sheet metal it but theres this weird corner at the top of the pyramid?
Make a plain pyramid ok but need it to have this inside as-well. Trying to make this out of one sheet that bends into itself pls suggestions :(
wayne_sauder
Member, csevp Posts: 629 PRO
If you can adjust the shape, it is possible to get something like this.
Also, if you are making this from paper or something that can be creased, you can bypass the rules that apply to sheet metal manufacturing and get this as @STEG mentioned. If you are trying to make this from sheet metal, I don't think the shape is possible in one piece.
https://cad.onshape.com/documents/8b9671e5e02a97bb2275cf7a/w/45204c874ab54e01d4bb8a12/e/1f161ed71305cd78bfd3d027
2
Not sure it is feasible but a way I see you could do it would look like this unfolded:
@elena_sknny
WOW this is perfect, I wish I could understand how you did it! Thank you so much Wayne!
