New Feature: Text path
jnewth_onshape
jnewth_onshape Member, Onshape Employees Posts: 89 image
Here is my latest custom feature: Text path.
The purpose of this custom feature is to lay out characters, words, or number sequences following a geometric arrangement (clock faces, wheels, dials) or alignment.
You can watch a demo video here: https://www.loom.com/share/19705d168c314cedab26787a13961b64?sid=2e4d09f9-bae3-4f08-857d-38b7ea599fa2
You can get the feature here: https://cad.onshape.com/documents/4e187c2b2f7f4974f4e2b612/v/04e7ad76e7b3e4008b7632cc/e/8639f00c4f54af50704861a9
Some common examples (arranging numbers for a clock):
Or arranging numbers along a slider track:
But it can work on most surfaces, even irregular ones:
Let me know what you think!
    S1mon Member Posts: 4,636 PRO
    Nice!
    I could have used this a while ago:
    As a side note, if you need to tweak kerning, you might still want to use the Surface Text custom feature. It doesn't do the sequences of numbers or handle some of the cool options of Text Path, but it will lay out text on a curve.
  • GWS50
    GWS50 Member Posts: 537 PRO
    Thank you this will come in very handy. Just did a job laying out text which I hd to do manually....as you can imagine it tool a while!
  • jnewth_onshape
    @S1mon Is kerning useful for this type of tool? I assumed if users needed that level of text control, they would be better suited to a purpose-built application like Illustrator, which can generate assets to then be imported. If this is a poor assumption please help me to understand what level of text control is required. I mostly wrote this to meet my needs (similar to the mold inserts you shared above - a great use case) but would be happy to expand the featureset as needed.
    @GWS50 Yes, Onshape's text tools are good enough for laying out one or two strings or characters, but for number sequences or geometric arrangement of different text elements, I think this is a better tool. Or at least that was the hope ;)
  • MichaelPascoe
    edited April 2024
    Dope! Thanks for sharing!
    Nice icon too B)
    @jnewth_onshape
    With kerning:
    without:
    One could argue that this is a font problem, not a need for kerning. The gap between the 'A' and the 'D' looks like a mistake without adjusting the kerning.
  • jnewth_onshape
    @MichaelPascoe "Good artists borrow, great artists steal" -- me, i just made this up now.
  • klaus_krämer
    klaus_krämer Member Posts: 96 ✭✭✭
    edited April 2024
    Great work! Hope it'll come soon as a tool.
    I have worked with surface text, with which I have some problems. I'd like to "carve" the letters 0.4 mm deep into a surface and then extrude these new surfaces again for 0.4 mm to be level with the surface again - but as seperate parts. It's for text on the first layer and non protruding text.
    With Surface Text I haven't found a way to do this yet. Text will always stand out from the surface.
    Is Textpath capable of "engraving" text as seperate paths? Something like that:
    The Text has first been removed / carved into the body surfeace and the next step is filling the removed letters with extrusion mode "New", to get all letters as seperate parts. Thus I can use different tools in my printer (Prusa XL) to print text in different colors - smooth an not protruding.
  • jnewth_onshape
    edited April 2024
    Hi @klaus_krämer
    Because text is (in my experience) sort of weird to work with, I didn't make a lot assumptions about how designers will use the text. In fact, the default Text path behavior is to not produce parts at all - just sketches:
     If the user wants to create parts, they select the "Create solids" option:
    From there, you can do a boolean subtraction to subtract the text from the base part, but select "Keep tools" to leave your text bodies:
    And then you get what you want:
    Alternatively, you could just create the Text path sketches, then re-use the sketches, once for engraving, once for extruding.
  • klaus_krämer
    edited April 2024
    Thanks, @jnewth_onshape ! I appreciate your help.
    While you were typing I texperimented a little more and found the sketches. From there all has been easy ...  :):
    I know, I'll love that feature!!!  <3
  • klaus_krämer
    edited May 2024
    I wasted lots of time to find out how these paths can be created:
    1. Created a new plane
    2. Created a sketch on that plane with a simple line
    3. Extruded a surface from that line into the cylinder
    4. Created the path by creating an 'intersection curve' of the cylinder surface and the newly created surface (from point 3)
    Whether that's the most elegant way - I doubt it, but eventually it has worked out after some desperation ...
  • eric_pesty
    You can use "projected curve" to skip the extrude... Or you might get better results using the "wrap" tool
  • jnewth
    Hey @""klaus_krämer"
    As @eric_pesty intuited: I used a projected curve to transfer a line on to the surface:
    if you open the doc containing the featurescript, go to the "examples" folder and you can see how I created all the CAD used in the photos and video.
  • yann_roth
    yann_roth Member Posts: 2 PRO
    Could the feature of crating solids also contain the bolean operation directly? this would make it even more usefull and seamless. (At least for me)
  • jnewth
    edited April 2025
    Hi @yann_roth You're probably right- this is often what users want to do immediately after creating text solids. Something clever you can use in the meantime is @GregBrown "autoboolean" custom feature which takes a feature as an input. This works the way one would hope, by getting all the bodies created by the input feature and joining them to some other body. It makes that last step quite simple.
  • jnewth
    @vanowm Yes there is, though Onshape's way of doing this is a little hokey.
    1. create your variable (use the type "any" for string)
    2. in the feature, right-click the text field and select "convert to expression". This means the field is now interpreted as an expression.
    3. you can now put in your text variable (so long as it is actually text):
    4. number type variables will misbehave:
    You can deal with that by putting in the expression "toString(#custom_number)"
  • _anton
    _anton Member, Onshape Employees Posts: 555 image
    (You can also create a new variable straight from this dialog: type # after you convert the field to an expression.)
  • jacob_rickey
    jacob_rickey Member Posts: 2 ✭
    As a feature request, could we have an option to make a the "Create Solids" allow extrusion, with a New, Add, Remove, Intersect option, this would use less objects, especially for cases like your original use case of MTG number wheels, where the numbers become part of the meshI have made a fork of the version bladec forked (https://cad.onshape.com/documents/3888fd8b00af2e7b4103f42d/w/34f2e031648e6cd11429949b/e/e082d95810228972b5aa9199Error)My version with boolean features:
    There was an error displaying this embed. If you wanted to implement it into the original, outside what bladec did, i set common.fs to export ()
  • joshua_wentworth079
    joshua_wentworth079 Member Posts: 2 ✭
    Did the adjust offsets feature get removed? It does not show up in the feature script for me.
  • jnewth
    @joshua_wentworth079 it's present in the latest published version. You are probably using an old version of the tool. Here's a link to the latest, but probably there is a blue dot next to your tool in your custom feature tool menu, and clicking that (or right clicking, cant remember) will let you update. You want Release 3.2.
    https://cad.onshape.com/documents/4e187c2b2f7f4974f4e2b612/v/53149e0c654047e1353c46dc/e/e8c85370413ae1136b63f9df
