Face relative coordinates for a sketch
marena_richardson
Member Posts: 20 EDU
I have a feature script feature where the user has selected a face, such as one side of a cube. I want to draw a sketch on that face. I can draw a sketch on that face but it still originates from world coordinates. How can I make the center of my sketch the center of the face I am drawing on?
newPlane = plane(oldPlane.origin, oldPlane.normal, newXDirection);Planes have right-handed coordinate systems, so you can't get symmetric sketch by manipulating sketch planes only. If the faces are in the same plane, you can use MIRROR constraint in the same sketch. You probably will be using sketches to make extrude. It might be easier to build the body you are looking to build and then mirror and transform it.
I think it's easier to just have the sketch normal point opposite the face normal -- the default extrude direction will be wrong, but that doesn't seem like a big deal. The other possibility, like I said above, is using opTransform or opPattern on the sketch itself, which can take transforms with negative determinant.
