How To Reverse Text With Surface Text?
Hi. I am a newbie to both 3D and On Shape and appreciate all the help I can get.
I have used surface text to create a curved text and want to reverse text like I can when using Sketch text. I cannot see how to do this.
Thanks
Randy
  • jnewthjnewth Member, OS Professional Posts: 110 PRO
    Use "Text" instead. The latest, Release 3, does all this stuff:
    Read about it here: https://forum.onshape.com/discussion/23648/new-feature-text-path#latest
    Get it here: https://cad.onshape.com/documents/4e187c2b2f7f4974f4e2b612/v/a94c2b1949ec131c8d9eb61f/e/3458f1d46464375effca78a5
  • randy_duffyrandy_duffy Member Posts: 4
    Thank you. I loaded it and it seems to be very powerful. I don't fully understand how to use. Are there any tutorials of the basics?
    The document itself contains an examples folder with many different part studios showcasing various aspects of the tool. I'd recommend you make a copy and go through the examples and modify the features.
    It is powerful but not complicated. Just experiment! That's part of the fun ;)
    If you are trying to solve a specific problem, please create a document showing the problem, then go to the share settings and and make it public and post the link along with your question. To share a doc, click on the Share button in the upper right corner of the screen, then go the "Public" tab, and make the document public.
