Beginner FeatureScript Help + Circular Pattern
RhettRobinsonRhettRobinson Member Posts: 187 ✭✭✭
edited October 2024 in FeatureScript
Onshape Document: https://cad.onshape.com/documents/e14506ff4d20585b290e1eb9/w/f810b9cde10509e5ce6e5ed7/e/e9f37d1a61a2dd62e3b9d8fb
After being interested in writing FeatureScripts but daunted by the task of learning it with zero coding experience whatsoever, I am knee deep in my first FS that isn't a step by step or hand holding example (I have done these tutorials so far: Building a Complete Custom Feature (FeatureScript) (youtube.com) and Create a slot feature (onshape.com). I have been able to incorporate what I have learned from these to get started on this one.
. What I am trying to accomplish can be seen in the tab "What I Want". I am creating a cut slot spec that has two options, 1 or 3, to cut into an existing tube based off of a mate connector selection. I have been able to achieve the one slot option (minus the filleted edge, haven't thought that one through yet), but am struggling with the 3 slot pattern. Based on some forum searching I think I am close, but I am not sure if my query for the axis of rotation is correct. I would like it to be the z axis of the initial mate connector that is queried, definition.MC. The other difficulty I have is that the slot for the 3 slot option needs to be opposite from where the 1 slot is cut. I think that creating an if else statement would allow me to flip the direction of the extrude, but I am still not solid on those. Any suggestions would be awesome, I am finding that there is a missing link between what I am learning/understanding vs. where I want to be. I am hopeful that I can crack it soon.
I do wish that the FeatureScript documentation had actual snippets and examples of each action (not sure of the correct vocabulary still), since it seems you either have to search the forum for an example within code or existing FeatureScripts.
Thanks in advance for any feedback or help!
