Can you move comments? Tag more than one entity?
jeff_mcaffer
Member Posts: 94 ✭✭✭
Commenting is very cool. However I sometimes tag the wrong entity. Is it possible to change the tagging after the comment is added?
Related, it would be great to be able to add the same comment to many entities (e.g., "pick color" and tag 7 faces). Currently does not seem possible?
This is absolutely possible if you're talking about Drawing "Notes". Right clicking gives the option to a leader. The "Styles" diologue to the right side of your screan will give options for colours
I should have been more clear. I was talking about "Comments" in part studios. I've partially answered my own question in that you can delete the tag and tag some new entity if you get it wrong. There still does not appear to be a way to tag multiple entities with the same comment.
