Is there the option "exclude from properties" in configurated assemblies?
Roberto_VerduciRoberto_Verduci Member Posts: 29 ✭✭
Hi,
I need to release a multi-configured assembly and I would like to have a single part number for all the configurations. I noticed that the "eclude form properties" option is not available for assemblies. Is it correct?
Is there a way?
Thanks
    It was only recently added (Previous batch of updates) so I suspect not. Might be worth making an improvement request.
  • Rhett_RobinsonRhett_Robinson Member Posts: 148 PRO
    If you look in the comments for the last update, Onshape has addressed that they are working on it but kept it back from the release because they haven't fully understood the implications this can cause. It is in the future.
  • Roberto_VerduciRoberto_Verduci Member Posts: 29 ✭✭
    Thanks!
  • Frank_BertucciFrank_Bertucci Member Posts: 16 PRO
    Great idea to use this for part studios, would love to see it in assemblies also!
