Transform sketch entities
graham_lockgraham_lock Member Posts: 252 PRO
Hi,
I've been unsuccessful in finding an example of transforming sketch entities.
In my use case I need to rotate a rectangle about its centre.
So far I have:
skRectangle(sketchStartFormer, "rectangleStartFormer", {
"firstCorner" : vector(centreStartXmm - (width / 2), centreStartYmm - (height / 2)),
"secondCorner" : vector(centreStartXmm + (width / 2), centreStartYmm + (height / 2))
const rotationMatrix = [[cos(startRotation), -sin(startRotation)], [sin(startRotation), cos(startRotation)]] as Matrix;
How do I apply this (if it's correct) to the rectangle and rotate it about its center?
Thank you.
  • Caden_ArmstrongCaden_Armstrong Member Posts: 316 PRO
    You have a few different options,
    - Calculate the four corners and create 4 line segments (this is how onshape does aligned rectangles, probably how I would do it in this case).
    - Create rectangle, solve the sketch, and use opTransform to rotate it, just note that opTransform takes in a transform not a matrix.
    - Create the rectangle and use sketch constraints to rotate it (personally my least favourite option)
    www.smartbenchsoftware.com --- fs.place --- Renaissance
  • graham_lockgraham_lock Member Posts: 252 PRO
    Thank you
