How to delete a tab folder?
jeff_mcafferjeff_mcaffer Member Posts: 98 ✭✭✭
I'm sure I'm missing something, but this has been driving me crazy. I can create tab folders a document, but I don't see any affordance for deleting them. Searching the help/forums/google it seems like this is (was?) intended?
  • jeff_mcafferjeff_mcaffer Member Posts: 98 ✭✭✭
    Thanks @Matt_Shields. That's the least intuitive name for an operation I've seen in a long time. Especially because AFAICT there is no "pack" and all the other tabs have a "delete". 🤷TIL
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 949 PRO
    "Unpack"
  • jelte_steur_infojelte_steur_info Member Posts: 655 PRO
    edited October 2024
    it's because it doesn't delete the content of the folder. the documents inside all remain, just no longer in the folder.
    Delete suggests the behaviour that it deletes the folder including it's content…
    SO if you would want to delete, you go into the tab manager, select all documents inside it, delete them and subsequently unpack the folder.
