hello, is it possible to create a decent mesh with Onshape?
  • Urs_Egger_REACTUrs_Egger_REACT Member Posts: 110 PRO
    The more spline points you make, the more likely it is that you will get a crease. Try to make as few spline points as possible and control the shape with the magnitudes of the spline points.
  • Robert_DeclosRobert_Declos Member Posts: 8 PRO
    I'll try, thanks
  • MDesignMDesign Member Posts: 1,086 ✭✭✭✭
    Is that one loft feature or multiple or what tools did you use to create the surface?
