REST API - Exporting to STEP works, but exporting to OBJ does not
guillauem_d
Member Posts: 20 ✭✭
Hello there ! 😉
I'm trying to export my sheet metal part using the REST API, exporting it to a STEP file works fine using the following method :
• Initiate the exporting procedure using /api/v6/assemblies/d/{}/w/{}/e/{}/translations
and payload = { "allowFaultyParts": True, "angularTolerance": 0.001, "formatName": "STEP", "storeInDocument": True, }
• Wait for the /api/v8/translations/{requestId} requestState to be DONE
• Download the STEP using /api/v8/translations/{requestId}
It works great, but now changing ‘’formatName’’ to ‘’OBJ’’ gives me the following error "Invalid resolution parameters were specified"
What changes to the payload should I make to make it work with OBJ ?
Thank you in advance !
Caden_Armstrong
Member Posts: 407 PRO
Each file format requires different inputs. Same as the user interface shows different options.
For OBJ Files you need to include resolution="fine". other values are "coarse","medium", and then I think you can do custom with some other additional properties such as distanceTolerance, maximumChordLength, angular tolerance.www.smartbenchsoftware.com --- Renaissance --- fs.place
Experts in Onshape Automation - Custom Features and Integrated Applications1
Indeed, after adding the resolution paramater, it works perfectly, thank you so much ! 😁
