How To Rotate A Parametric Curve
fenton_lewis
Member Posts: 6 ✭
I recently downloaded this Parametric Curve feature from Mahir to try and make an Areospike. I have been trying to rotate it around the center point but with no avail, do you have any suggestions?
Your document is view only, so it's a little hard to see what you're trying ot do, but I think you're trying to do a Revolve? You need a revolve axis.
Thank you Matt that is perfect. When I tried to revolve it, it would not let me rotate it.
Would you please send me the link of your thing to me please, Thanks.
https://cad.onshape.com/documents/7b265f9547ea96d0c8af0858/w/a086dde488156e48d7b16a86/e/3487368c5bdbad24aa84214d
Thank you, I now plan to print them, I was wondering if that was possible, because they have no thickness. if it is not at the moment how do I make them thicker?
Thank you again
Thicken.
