Adding a dimple to inside of a hole
gary_laffoongary_laffoon Member Posts: 2
I have a rectangle 13mm thick with a hole in the center. I need to place three dimples at 120 degrees around the center level of the hole. I'm totally lost as to how to do this. Also I am new at using Onshape and CAD in general. The dimples are to act as a capture point for a large nut, they need to be 1.5mm hemisphere. The hole is 34.5mm diameter. Any help or point me a good tutorial will be greatly appreciated.
