Sheet Metal Table, Flat View.
I have a model that contains 3 parts. they are all simple sheet metal flat parts. when I choose the Sheet Metal Flat View I can only see the first part usually "part 1" I dont need to see them all at once, but how do I choose which part ie: part 1, part 2, part 3, is displayed in the sheet metal view? currently I "Suppress" part of the sketch that I dont want to see which will then switch to the next part in the sketch and then that will be the default sheet metal part that is displayed.
I am wondering if I am just missing something simple.
Thank you in advance for all your help and advice.
nick_papageorge_dayjob Member, csevp Posts: 962 PRO
There is a drop down list on the upper right portion of the sheet metal view where you can select the part.
WOW, so simple, I feel dumb. Thank You so much for taking the time to answer my question.
