How to change profile line?
j_m725
Member Posts: 6 ✭
Hello guys as you guess im quite new and is a bit phrustrating to learn even if it is much eas hehe.
Could you tell me how to change the profile of this rod?
[url=https://ibb.co/tJrDxMC][img]https://i.ibb.co/9r5WV9Y/image.png[/img][/url]
I wanted to make lightly wider from the bottom, something like this.
[url=https://ibb.co/5Ykq4vK][img]https://i.ibb.co/KNDCh7K/image.png[/img][/url]
But i have made the extrusion from begining and now i dont know how to change the thickness of the rod to make it something like 4mm on top 5mm on bottom.
Here i add a video showing it.
https://youtu.be/56YuTYOML2g
And the file, so will be easier to click byyourself and discover my mess XD
https://cad.onshape.com/documents/1622b74b5a2fcf0930df2fbc/w/5a910d446d7171233876a4da/e/6cb05635c52c1403976700c6
https://file.io/JzgVU76tKYEx
Thanks guys!!
MichaelPascoe
Member Posts: 2,685 PRO
Remember not to use the Fixed constraint if you intend to change dimensions. In most cases, Fixed = Bad
Replace the complicated splines with simple arcs:
Here an example of how to fully constrain your sketches and use the extrude, revolve, and mirror features:
https://cad.onshape.com/documents/bdc8473bc8903c12d58898b0/w/1c1a321e1af908fcb4ff2b52/e/…
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
Please share a link to your Onshape document so we can help you better.
Changing an extruded profile usually involves opening the original sketch that was extruded, and modifying it or changing a dimension. Don't forget to complete the Learning Pathways so that you will be familiar with how Onshape works: https://learn.onshape.com/catalog?labels=%5B%22Learning%20Format%22%5D&values=%5B%22Learning%20Pathway%22%5D
done my friend
I hope is not too dificult, and you can help me
Thats perfect, i got it, thank you very much for spend your time on it, greetings ;)
