Appearance Dialog
Hi,
Is it possible to use the Appearance Dialog from within FS?
Thank you.
Caden_Armstrong Member Posts: 332 PRO
Nope.
But you can still set the colour of faces/bodies/wires/sketches with the setProperty function.
You'll just need to make your own UI inputs for the user to select colour.www.smartbenchsoftware.com --- fs.place --- Renaissance
Custom FeatureScript and Onshape Integrated Applications0
Nope.
